Loading nomad file into web demo version
I want to share my model which uses textures and vertex color with my coworker so can take a look at it. I tried exporting a nomad file format and import it into the web demo but nothing happens.
Is this supposed to work? Would it be possible to open projects normally from the files folder?
Just drag & drop the nom file in the webdemo window.
Normally it works without any problems.
Only e.g. Matcaps are not taken into account.
It should definitely work.
Either by simply drag & drop or using the import button in the files menu.
It freezes…
I tried to export individual objects from that scene… and some work, some don’t. The dubious thing is that two objects that import fine individually , don’t work when exported together.
Can I send you a file Stephomi?
If it freezes then it likely means it’s a big file and the browser hits the memory limit.
You can send it to me but if it’s a big file, it’s likely the cause.
The entire scene is big but I am only exporting small parts
Ok it only doesn’t work on the iPad Webbrowser. Desktop works nicely.
I use the WebDemo all the time on my iPad with Safari - I have no problems with drag drop files. I have several iPads - different models - all ok. Maybe it is the file size …
