Is there a way to move stamp? or move mask area for accurate alignment. Is there a way to hide the mask instead of hiding the model
You can’t move mask or stamp.
You can hide the mask by using the button in the bottom bar, with “mask” written on it.
Thank you stephomi.This mask hide button hides the part of the model, sometimes I don’t need to hide the part of the model, just need turn off mask visibility ,similar zbrush turn off “viewmask”
Expect a tool like Stencil that will be more precise when using alpha to sculpt model
Ah ok, like clearing the mask but with the possibility of showing it again.
Similarly to the “hide scene painting” in rendering menu.
Yes, thank you. That would be useful.
