Invisible Part of the Mesh for Drag Tool
Unfortunately, it is not possible to grab hidden points with the Drag or Move tool. This is important to work exactly along the XYZ axis.
Is it possible to make only the mesh invisible (like the mask) - so you could grab the points…
Only hide the mesh with the (Mask) - but do not block it when sculping.
I hope it is understandable what I mean …
See the Video
Greetings
Just mask everything but the top and use use the Move tool with a bug radius.
Or use the « normal » button
Ok the Normal button works and you can still use the symmetry.
But a mesh that can be invisible but not masked would still be useful - then you can get to parts that you otherwise can’t get to. For example, inside a mouth sculpt ……
I don’t really like the idea of editing something invisible.
