iOS 18.5 corrupting files?
Question has anyone else been having issues with the newest iOS update (18.5) causing corruption with some of your files? I have a file where some of the mesh is missing when I open it on my ipad pro 13. I uploaded and opened the exact file in my mini ipad and the mesh is intact. The Nomad versions are the same, the only difference is the iOS versions, mini is still running iOS 18.3.1.
Is there a fix (if that is indeed the issue)? I did reboot my iPad Pro and still same problem. I also verified the same layers in each file.
Wondering if I will need to reinstall Nomad to see if that fixes it. Have attached screenshots and circled where the missing pieces are.
Thanks!
Don’t do that because iOS will delete everything in the iOS/Nomad folder.
Other than that, if it’s really the same project, check that settings are the same (cog menu).
For example “two sided” or “mask-opaque”.
And inspect value should be the same (option at the bottom, although none should make no difference).
I’m pretty sure iOS is not the issue, so it must be an option in Nomad.
You can check if there is an error in the log (debug menu in the top right → log options at the bottom)
That worked! The two-sided option was toggled off. I turned it back on and there it is. Thanks so much, I was stressed I would have to rebuild.
