Hi,
As a sugestion maybe align or not use the central space on vertical position so the central icons overlap with the new iOS feature to divide the screen.
It’s hard click on the icons so each time appear the divide screen.
Attach screen capture.
Try it in Landscape mode. You can also go into Display Settings and reduce the UI scale. There’ll be a gap between the top row icons and this won’t be an issue in either vertical or landscape. It also tucks away the UI neatly.
These IOS icons are a nightmare for every UI UX developer.
I stuck in several apps already because I couldn’t tap the icon needed.
The net is full of complains and questions how to switch it off.
From a lot of different app users.
Scribble was a nightmare, now this (generally not a bad idea but,…)
