You can either use radial symmetry for sculpting the indentations, or use a radial repeater to place smaller cylinders that you can subtract from the big cylinder using booleans or subtracting by voxel remeshing.
If it’s supposed to be a more realistic bottlecap with a hollow bottom probably the first option is easier
