How to add a loop cut to a cylinder?
I am trying out Nomad Sculpt for the first time after a brief struggle with Blender, and the one thing I have not been able to figure out is how to add loop cuts to a cylinder. I’m looking to model wine bottle sort of shapes… I thought it would be pretty self explanatory to build a basic bottle from a cylinder by adding loop cuts and adjusting the radius and bevel, but as far as I can tell there is not an option for that in Nomad Sculpt. Any ideas on how I could do this, or a different method I could use to create the shape I’m looking for?
Split - filling none - then join the splited objects - they weld together - then you have a new loop.
This. Also you could use the Lathe-Tool, which is perfect for this purpose.
Thank you so much! A few more steps than I anticipated but this should work exactly how I want it to!
Tube? Or lathe? I think both would be easier than editing a cylinder.
We think alike.
