Can’t crop correctly, for some reason removes the back
I lack context but maybe try disabling Symmetry?
After you mask the object
Hold down the mask button on the left and press anywhere on the canvas to invert the mask
Then use the trim brush to cut.
Thank you very much! It helped! Exactly what you need. and thank you very much for showing how to bring up the brushes menu, but it’s still better to show in the screenshot where to click. I poked all the brushes until I realized that I needed to press on the brush icon from above and after all, hell, you’ll understand that this is a button.
could you still help? I cannot rotate objects 90 °. how it’s done? I do not have a magnet, I have objects along the axes and degrees, numbers are not displayed. slightly turned the figure and you can start over.
Increase this slider to rotate 90 degrees
