Has the feature" press mask button and drag on screen" to clear mask been altered? In my case I just rotate the object. Also is there a list of alternative keyboard shortcuts available also to use both at the same time if you like?
I am still PC accustomed but find Nomads performance really stunning even in the webdemo!
Still working here. If you have lazy rope enabled you might have to drag a bit further even outside, but there should be no camera rotation with the default settings
There is a key bindings editor that lets you remap even ctrl and shift, you could try that if there is some other issue. Also maybe some settings like “pencil only”
