Is there a way to create a tight bend in a flattened cube. Trying some hard surface modeling and one part is a bent cover plate
Try masking with a sharp edge and then simply use the gizmo for the bend.
Hopefully this can help: Nomad Sculpt - Bending Tip (V1.65 -26.7.2022)
If not, Holger has some other videos as well that go over bending objects. Search through his stuff and he may have something.
