Gismo issue. Video is attached (PC version)
THE PLATFORM: Windows
NOMAD APP VERSION: 2.9.1
I’m having an issue with the gizmo/pivot.
Here’s what’s happening:
I change the gizmo position using the pivot tool (move the pivot point), but when I try to move the gizmo after that, it immediately snaps back to the center — the original position.
So even though the pivot appears to be changed, it doesn’t actually apply — the gizmo just resets to where it was before.
I’ve shown the whole process step by step in the video, where the issue is clearly visible.
I think you use multiselection - you need a joined mesh or a single mesh to keep the pivot …
It is the same with unvalidated primitives - you can change the pivot but after using the gizmo the pivot jumps back to old position - so you have to validate to keep the pivot.
Have you tried to bake the pivot in the Matrix - maybe it helps…
Will be fixed.
Until it’s fixed, you can do it like this. After setting the pivot, activate the pin feature. That way the pivot doesn’t change
