I create 3D scans using my iPad. I want to share my scans in VR, but I don’t know how to use Nomad Sculpt to create a PNG texture file, which is necessary for the VR world editing software I am using. It also requires FBX files, which I have no problem generating; however, I don’t know how to pull a PNG texture file from a 3D scan. Does anyone here have any ideas?
Pick OBJ as your export file type. This will create a texture map from your scan. You can then export your FBX file separately - I think nomad doesn’t support texture export in FBX files, only vertex colours.
Import your model and add the texture created for the OBJ export and you should be done
