Any tips on preserving layers and painting when uploading to Sketchfab? Is it possible? I exported as .glb and uploaded to SF, model looks fine but is black and shiny.
Maybe you must check the settings on SF, edit from your SF model, you have a lot of options.
Also, ensure to combine the layers with your model before export if not the layers aren’t exported.
None of those did the trick unfortunately but It could be me missing something else. I got through my task by UV painting in Procreate instead but I much prefer the painting flow within Nomad.
Did you turn on vertex colors in sketchfab?
Paint on layers will be ignored.
Disable “export layers” or merge your layers.
All working now, thank you.
