Just getting to grips with this amazing app. Is there a simple way to cut an object from another? Say I want to chop a shaft inside a square., can it be done using a cylinder? Cheers.
You can use voxel subtract for this…
-First select both the object using multi selection
-Hide the object that you want to subtract (
-Click voxel merge
#You can adjust the resolution of voxel merge inside topology tab
Yes, you can see it in action in the manual https://nomadsculpt.com/manual/scene.html#subtraction
