This is definitely niche enough to be a “ha ha no way”, but I figure it might be easy enough to implement that it’s worth asking.
I (and a lot of us, I’d guess) use Nomad for making things to 3D print. Being able to see in-app what surfaces are too horizontal to print without supports would be kind of amazing.
A view mode that colors faces (or vertices?) based on their angle relative to the world Y (Z? I forget what up is) axis would be really helpful. UI-wise would need a threshold input (so, anything below x degrees is highlighted) and, probably, a color selector. Maybe the ability to change the orientation against which the comparison is made.
I wonder, though, if matcaps could be made to render relative to the world instead of relative to the camera, if that would provide a simpler implementation of this (then just load a custom matcap with the relative angles colored as expected).
