Concerns tube snapping ON/OFF.
I have really placed a lot of tubes on surfaces the last few days.
It is really exhausting to switch the snap ON/OFF.
Couldn’t it be different?
Single touch = ON/OFF
Long press = change settings (like the icons in the bottom menu).
If you have a lot of overlapping tubes - but you want to snap on the main surface - then you have to deactivate the snapping very often to avoid snapping on the other tubes…
It would also be very helpful if you could deactivate snapping for UNVALIDATED objects - just a thought.
