THE PLATFORM: Windows 10
NOMAD APP VERSION: 2.9.29
I just experienced a couple crashes that resulted in the files I was working on being nulled out (i.e. the file sizes are still correct, but the contents have literally been set to zeros). Each time, I had completed a save successfully (apparently, at least - the little pop-up confirming the file write had appeared), and had resumed work, when I had a hard freeze (had to power-cycle the machine). After restarting, the file thumbnails are small cartoon beetles, and attempting to open the file produces a “.nom → magic doesn’t match” warning. Using a hex viewer, the files are composed entirely of zeros. Reviewing the crash log, these events are not captured. The files were just under a million polygons, and memory usage(?) displayed in the upper left-hand corner is about 340 MB/3.4 GB.
Losing files like this has me resorting to a workflow where I keep bouncing between two file names, to minimize data loss if a file is corrupted again, but obviously, this isn’t ideal. I am aware I’m a version out-of-date; I also realize that the hard-freeze could be an OS/hardware-level issue, but I figured I should still do a bug report, though, as I haven’t seen any references to this failure mode before, and the part where the file is nulled (while retaining the correct file size and displaying the file-write confirmation) seems like a possible Nomad bug.
Regards,
-Luke I.
