File crashing when using on both iPad and PC
THE PLATFORM: iPad, Windows
NOMAD APP VERSION: 2.12
I bought and used Nomad on iPad and Windows. I use the same disk (my PC as the server for Nomad settings and files) for iPad and PC.
After using it on both, I opened the file on PC, and it crashed. I reopened it on iPad, and it also failed. This happened more frequently after I updated Nomad. Is there any way I can retrieve the file?
To Stephomi: I sent you a DM including the .nom file in case you want to check it.
Thank you.
The file loads fine for me.
I would suggest copying the file elsewhere first (do not load it directly from a cloud folder).
I’m confident this is not a load/save issue in Nomad but rather a folder sync thing.
Yeah, I tried moving the file to another folder and importing it into another scene, and it works fine.
Thanks a lot, Stephami.
