Can’t export file
Bug reports
Hello, I’m having a lot of trouble exporting a file. It’s larger than it should be so if I try to remedy to lower the poly count it crashes. If I try to export the file in any format other than glTF it crashes. If I try to open the glTF file in any program that opens glTF files it fails.
I’m at my whits end so if any one has any suggestions please let me know.
Thank you
Split in parts, then use save as (only selected parts) and save single parts. Then decimate. Then put the parts with add to scene together.
I will try that, thank you.
