Major problem
I have just completed a model after four months of work. When attempting to export to OBJ and GLTF the application crashes. I can export to all other formats but these two, which are the most critical ones that I need. I had cleared all of the cash and even reset all the defaults, and it still does not work. Is there any possible fix for this.
What’s your poly count? Most likely you need to decimate your model.
Hi, Roger. Thanks for replying, but yes, I did decimate almost every component on this automobile that I created and after decimating it, i’m not having any luck exporting to those two file formats.Is there anything else that I can do
Get BlueMail for Android
Assuming you have a decent computer, maybe you could save the file as .nom and use the demo of the desktop beta to open it and export it from there.
If you’re working on an iPad or Android, try sending the file over to Google Drive from your file browser then see if you can pull it into the PC beta, and export as your preferred file type from there.
sounds like you have multiple components. Try exporting them in groups. You can export based on whats visible on screen or whats selected.
