Camera and gizmo bug
Bug reports
As you can see the first bug is on the camera; if you tap the snap cube on top its perfectly align on top but some times if you tap or accidentally tap the background it’ll loose the alignment of the camera; and it’s not nice for fast work, you have to lock the snap cube every single time to eliminate the bug. And the second bug is gizmo misbehavior, when you tap the snap cube (on top specifically) the gizmo is doing wierd thing you can see it in the video.
The gizmo bug has been fixed already.
If possible you can test the web demo to see if a particular bug issue has been fixed for the next version nomad - WebAssembly
Not a bug then?
great it fixed in web assembly thanks
