Aaaaaand a little tutorial how to share brushes. Yes!! We can share brushes
Do it on your own risk. I tested it once and it was working with my older iPad.
Tutorial for IOS.
Do following steps:
With files app go “on my iPad” and choose Nomad folder. Check, if there is a “tools” folder. If not, you haven’t generated a new brush icon yet. To do so, open Nomad, long press on any brush icon and choose clone. Now a tool folder is generated in Nomad directory. (You can delete this brush icon later)
Maybe you can directly generate a “tools” folder with files app, but I haven’t tested this.
-Close Nomad
download the json file Brush settings file
and store it in Nomad/tools folder.
Download this Gradient Alpha Gradient Alpha
and store it under Nomad/Alpha
4
Open Nomad again. In your brush list, there is a Gradien_Mask brush on very bottom working exactly like mine.
You wanna uncheck symmetry, depending on what you want to mask
For those who don’t trust this way or just are not experienced enough to trust themselves, here are my settings. You can just clone the mask brush and change the clone with following settings and the gradient alpha.
If you find better once, please share it here.
Like the stamp tool.
I can’t tell you if it will work to copy the json file into nomad brush folder and copying the alpha into the nomad alpha folder .
To be save, just download the alpha and use the settings from my list.
On IOS, there is a folder called tools. There are this json files stored. I guess its a container with all settings for new save brush icon…I don’t know if all brush settings are saved with that… I guess I better delete that file before someone gets into trouble…
Ok folks. Brush sharing is working. Tested it on my old iPad Pro.
I am on IOS only and have not a clue about Android. It would be nice if some Androids would share a little Tutorial as well in here.
