Is there a check box for backface masking that I’m not seeing? I feel that it’s there and I’m just not finding it.
Is this what you mean? Swap between 2 sided or 1 sided - same as backface culling. Can do this on a per-object basis in the material menu.
Do you mean only masking one side of an object so if you trim or cut it doesn’t cut right through?
Yes, thank you @knacki that’s what I was looking for. I was painting a mask and getting frustrated since it was putting the mask on the opposite side of what I was painting. Thank you to @Bezzo for your screenshot showing material backface culling. It’s good to know where that’s at
Thanks I was wondering the same thing.
Thanks
@knacki this works, but now the setting is under filters rather than brush
