Depth Painting
Just saw that a new update came through. I don’t think this would be a bug, so I thought I’d try posting here.
As usual, I’m likely just blind in terms of where it moved to. Been searching for where the depth painting slider has walked off to though. Currently, layer filtering is the only thing below where it used to be. What is the new method for painting that way again?
Depth masking in filter menu, same for clay flatten previous offset slider.
But the way it works is not necessarily finalized, I might add back the single slider control.
Sorry about that, I thought I went through that menu. Skipped over it at the bottom somehow. Thank you.
Plus some extra sliders to play with. Even better.
