Version 1.47.
The app crashes I think everytime I am doing some memory draining actions and the same time an autosave is saving it’s file. I also have a little lag during autosave.
It looks like memory problem but I have 4GB free RAM. I’m using iPad Pro 2020.
Here Ididn’t turn on an autosave popup, but I am pretty sure it was autosaving. When I tap on the highest level of multiresolution, the app crashes.
Here I turn on a popup and you can see while I’m using the tool and autosave count came to 0 the app crashes.
Indeed there is a bug when you create a layer that is not on the highest resolution.
There is a lot going on when autosaving (it could be faster but then it would take more memory so it could crash easily).
I could probably improve it by running some of the operations in the background but it makes things more complex.
Files can be huge, it’s not a 2d apps, several hundreds of MB sometimes (and there are zipped as well).
Hmm… it shouldn’t happen so I’ll take a look.
That being said you aren’t supposed to do anything while it saved (actually the save popup appears only after 1.5s of inaction).
