Access to Android/data/ is now blocked by default.
You now need to use a File Manager app (it should be vetted by Google for approval), some information on reddit.
Personally I’m using “X-plore” for now.
I just updated Nomad to 1.37 and the export “should” work fine.
I could only test on a Samsung Galaxy Tab S7 (but someone told me he got issues on the same device so I’m confused).
Please let me know if you got a crash on import or export (OS version, Nomad version, Device Version).
Export obj/stl/gltf works for me but files are greyed out so I can’t select an existing one. I can type in a new filename then it works but when I use an existing filename it gets renemed to file(1).stl for example. Import is fine btw, (Android 11, 1.37, Tab S7)
Sorry I put the wrong tablet btw, it’s the S7+, that might make a difference. My File App reports version 12.1.00.12, I can uninstall updates for the App, but then still have version 12.1.00.12 and the greyed out issue remains.
