Even if I check the save load UI and save the project, restarting it resets all settings. Pressure sensitivity, dynamic topology, and all the other checkboxes on or off…
Is this working as it should? I’m iOS, iPadPro.
Yes all settings related to brushes are not saved for now.
I plan on adding custom brushes instead.
I don’t really want to save default brush settings as I know some users might fiddle with some brush settings and break the behavior.
As for dynamic topology it’s a mesh attribute not a global settings, so I could save it in glb and then convert back to dynamic topology on import.
It’s a hassle to get the dynamic topology turned on and the screen details unchecked each time you start working. It would be nice if these settings were saved as well (sometimes I forget them)…
