Zoom behavior. It is WEIRD on PC!
Why the zoom moves always away to the left on a PC?!
When I try to zoom in and out the zoom outworks at it should, but when I zoom in then starts to shift to the left.
Why so? A zoom in and out must work in position and not starting to moving to the left.
I just bought Nomad so I need to find my version too. I am using the Nomad Sculpt version 2.9.22.
By the way. You can get rid of the windows horrible OLD and PRIMITIVE pop-up windows.
Nomad is soooo COOL, but when I see any OLD and PRIMITIVE windows is so annoying.
zooming can feel a little weird because it always zooms to the cursor position rather than the screen center. and since youre forced to click outside the mesh when zooming by usual means, it will pan off-center. i solved this by setting up zooming on right click so i can click on the mesh
you can get rid of the windows native dialogs by checking “use nomad dialog” in interface settings
Thank you so much. I will try it.
It’s not weird, I would say that’s how a sculpting app should work. Zbrush is a bit similar.
There are some options to control the pivot management though, including zoom out behavior.
Technically you are not forced, but it depends on your setup (and customisation)
right/secondary click, two fingers zoom, “force camera” in the camera zoom hotkey “…” menu (at the expense of triggering some mask gesture, etc), custom hotkey, etc
Hey! The right zoom did the job!
THANK YOU!
@stephomi I will check those options too.
Thank you!
IMPORTANT!
@stephomi
I think you need to have a look on this.
It is important if you one day are planning to implement FULLY the 3Dconnexion application.
If you see the rose tiny dot on Nomad you will see that moves ALWAYS to the center will I zoom in and out.
Once that point reach the EXACT middle of the canvas, then stops to move and will zoom from that point no matter where the model is.
As you can see the model will be push up, down, right or left depends where the tiny rosa dot is placed.
Look at the video I made below.
there are already lot of topic on 3dconnexion, use the search button in the forum.
Hi, yes I already saw a couple and lost a bit of time.
None one is the right solution and for me is not working.
Workarounds is not the way to have a solution, already suppose to be integrated.
I will still looking after learning Nomad.
At the moment my priority is to learn the software.
Thank you for your support.
BTW! My last note and was NOT about the 3dconnexion. It was about the behavior of the zoom in. The INITIAL topic.
Nomad has been there since years, do not expect any changes in the camera.
I have never say that should be change.
It is comfortable = YES!
It is better to have this feature = YES!
I can share my opinion = YES!
Can I ask this feature and get ingonerd = YES!
Do I enjoy now the program as it is = YES!
My workflow will better if I have this feature = YES!
Did I ask to implement any feature = NO! I just expose that there is BUG in the zoom.
Will be ignored = MAYBE!
