I miss some form of little panel that indicates the current size, for example, when using the Gizmo for scaling. Or maybe something akin to Blender where you can dial each coordinate size separately or locked together. This would be particularly useful when outputting for printing. I prefer to scale within the program and work with actual sizes rather than scaling in Bambu Studio. The workaround with a template to compare sizes is a bit arcane.
Yes, that’s good, thank you. I didn’t realise that this facility already exists in that menu.
Please note that this feature is currently only available on PC version 2.9 and above. Android and iOS users may need to wait for a new version update from the developer.
I have a question: is there a way, using the new organizer tool, to make the box follow the rotation or change in angle of the object?
Only through the “local/world” toggle on top.
But it will only work if the mesh has been transform with the gizmo.
I tried it, it worked with the lattice but the organizer is still the same.
