THE PLATFORM: MacOS
NOMAD APP VERSION: 2.9.29
Hi, I just got an XP-Pen Artist Pro 27 Gen 2 and I’m trying to use it with Nomad on macOS.
What I wanted was basically the same workflow I have on the iPad. Pen for sculpting and touch for moving the camera around.
The pen works fine and touch itself also works on the Mac. In Safari for example I can scroll with two fingers and pinch to zoom without any problems.
In Nomad it seems like the touch input is only recognized as a mouse though. I can rotate the model with one finger, because that basically behaves like a left mouse drag, but two finger pan, pinch zoom and two finger tap for undo are not recognized at all.
I also tried turning “Use Wacom Multi-Touch” on and off, but that doesn’t seem to make any difference.
I did some testing on macOS to see what the display is actually sending. The touch part of the Artist Pro shows up as a separate device called eGalaxTouch D5310B, Vendor ID 0x0EEF, Product ID 0xC300, Usage Page 13 and Usage 4, so macOS does see it as a touchscreen/digitizer.
I couldn’t get the individual finger contacts directly, but the gestures themselves definitely arrive in macOS. Two finger movement is coming through as continuous scroll events and pinch zoom comes through as a separate gesture event.
I even made a small bridge just to test it. It converts the two finger scroll events into a middle mouse drag and the pinch gesture into mouse wheel zoom. With that running, two finger pan and pinch zoom actually work in Nomad.
So from what I can tell, the hardware and the XP-Pen driver are sending the gestures, but Nomad doesn’t seem to recognize them as touch input.
There is one separate limitation on the XP-Pen side. Two finger movement seems to be axis locked, so diagonal movement gets interpreted as either horizontal or vertical scrolling instead of proper free 2D movement. I’m pretty sure that part is an XP-Pen driver issue.
My question is mainly whether non-Wacom multi-touch displays are supposed to work natively in Nomad on macOS at the moment.
If they are, this might be a bug. If Nomad currently only supports Wacom multi-touch on desktop, then I guess this would be more of a feature request.
It would be great if the Artist Pro could work more like the iPad version, with the pen for sculpting and touch for orbit, pan and zoom.
I can also provide the logs or test anything if that helps.
