Hi Stephane, using -sub with Layer tool on a mesh layer doesn’t seem to remove the layered up mesh like it would do normally. Just thought I’d mention it, thank you!
You are confusing sub with the separate DelLayer tool, not a bug.
Hi Stephane, thank you for the reply! I definitely wasn’t getting confused dude 22 June 2022 - YouTube this is what I was on about. I did find however, after playing around, that if I switch back to Base Layer then back onto the Layer I was working on, the tool is then reacting fine with -sub.
In any case it act “normally”, so not a bug.
You can disable an option related to this behaviour in the tool menu.
Magic, thank you for your time & knowledge dude, much appreciated!
