Is there a way to use Bloom on a specific part. When I select a specific part and enable Bloom the whole model glows.
The threshold slider for bloom is basically saying ‘anything brighter than this value, bloom it’. Based on this if you make sure most of your model is of a certain brightness, and the bits you want to glow much brighter, you can then isolate it using the threshold.
One of the easiest ways to do this is to make sure the glowing parts are separate objects, and set their material to have ‘unlit’ enabled.
Okay, thank you very much for the information.I appreciate it. I one thing I am doing is isolating you the object that I want to glow, making it separate from the rest of the components.But I will work with the threshold and see if that does it for me once again, thanks a lot
