Im sculpting using the tube tool and twist function. I have a problem where I barely move the pin, it can twist insane amounts. Like -1500° when trying to stand still and make subtle adjustments of maybe 30°. The twist option is basically useless
I couldnt find a “sensitivity” option to adjust either… I tried a bigger scaled object, different resolution and still the same issue. Any ideas?
maybe double tip the pin and insert a value is an option?
I noticed if the circumference/radius (orange pin) is very small the twist function will sometimes freak out for me esp if there is several twists facing in different directions. Idk if you have the same issue but maybe scale that up, twist, then scale it down again?
Doesn’t really work for me
I did notice a slight difference when I made it wayyy too big, but I have a feeling it’s because 540 degrees doesn’t feel as much on such a big object. I’ll keep putting in numbers, it’s faster than scaling, but thanks for the tip anyways!
Yeah it’s what I’m doing but it’s not as « natural »
Oh I tried to make a new scene and it works fine…. I imported my old
Scene into the new one and it was the scale all along… It was too big, be careful when importing from another software
Twist speed has been fix on 1.93.
But in any case you can always single tap the dot and enter a manual value.
