Transferring data from iPad to PC
Which folders/files should I copy to transfer all my work from the iPad to my PC version? Do I copy the entire contents of the Nomad folder?
If you want to copy your projects or sculptures to your PC, it’s enough to copy the ‘Projects’ folder — the NOM files are your actual projects and sculpts.
If you also want to transfer your settings or your bindings, then go to the main NOMAD folder and copy the files settings.json and bindings.json.
Basically, all the JSON files can be copied to transfer your materials, settings, bindings, and so on.
Thank you for your reply. I want to transfer everything (alphas, backgrounds, environment, matcaps, projects, etc.). So it seems to me that I should take everything except perhaps “tmp_session” and “data” because those are the icons.
Then - yes, copy all the files.
