There's an error with the curvature stroke feature
THE PLATFORM: iPad, Android
NOMAD APP VERSION: 2.10/2.11
Version 2.8 was the original state. After the software update, when I opened the file again, it looked like this. After ruling out some possible causes, I found that the problem was with the “Hard Mix” mode in the curvature stroke, which caused rendering errors
In 2.9 I rewrote the blend modes to match Photoshop/Procreate.
A color flips to white at 50% brightness instead of ~75% before, which is why the pale petals go white now.
To get closer to the old look, you can lower the curvature opacity or try Vivid Light / Linear Light, they’re less harsh than Hard Mix.
note: there is a bug though, both bump/cavity slider shares the same blend mode. It’s a bug, but it was already like that on 2.8.
Oh I see, but I have two more questions. First, after the new version update, no matter how I adjust the curvature stroke value, the transparency preview next to it doesn’t change at all. I was wondering if this is a bug. Second, after the update, the maximum curvature value that can be adjusted went from 100% to 1000%, and the color turns white at just 50% brightness. That difference seems way too big
  1. Not a bug, the square only shows the color now. The % slider next to it is the opacity, and since it can go past 100% now, the square can’t really show it anymore.
  2. The 50% isn’t the slider, it’s the color brightness: with Hard Mix a color channel goes white once it’s brighter than 50%, whatever the slider value. The slider math didn’t change, 0–100% does exactly what it did in 2.8, I just allow going past 100% if you want a stronger effect.
I try to set one curvature to multiply and the other one to normal, but they both set to the same blend mode even if I have the option to set both the same in “off”.
Post above.
