Program alway stop working
2.5 Ipad version alway stop working when I use curve tool and it just random stop working a lot of time when I’m sculpting and I lost all my work
Could be so many reasons. Can you post screenshots, a video, or more information? The more you can show and explain, the easier it is to get to a solution.
At 0:19 when I use curve, the program stuck and stop working
I never have any problem with older version, but in this 2.5 new version, the program alway stop working while I’m sculpting, I lost a lot of my work I haven’t saved yet because the program alway stop working every times for no reasons, not only when I use curve
20.5 M Vertices may have something to do with it?
@RogerRoger the geometry under radial seems low res (6k) so it shouldn’t be an issue.
The update is under review and hopefully it should be fixed.
I can’t be sure because these crashes are random.
(If you want to be sure you can send me the model at support@nomadsculpt.com or simply ask for the beta iOS TestFlight to test if it fixes your issue).
I just see this guy have same issue with mine, hope you guy fix it soon
“The update is under review” (by Apple)
Thank you so much for super quick update
I’d assume so too, except my projects have historically been 1M vertices and I’ve never had a problem. After the update, none of my models that were able to be Booleaned will Boolean now. It either freezes or crashes entirely. I can’t get any work done anymore :sweat_smile:
