After the latest update, when I use Move or Drag, the minimum unit that it works with has gotten bigger. Even if I move with a pen, it doesn’t work at very fine distances, and it only starts to work after a certain distance, so is there a setting item related to this?
Pencil in Nomad always had issue with single/double tap on the viewport because there was no minimum threshold (e.g: hard to select another mesh).
I added a small threshold on latest update to fix this issue.
I don’t think that’s the main issue though.
There’s a “jump/discontinuity” that happens on the first deformation when you use the pencil, and that’s a bug that doesn’t happen with fingers (even though the threshold is bigger for fingers).
For now I don’t want to remove this threshold, fixing the “jump” should improve the situation though.
