400+ brushes/tools, all designed to work together. As well as that, I’ve put over 2 hours of videos on YouTube explaining how to get the best out of them. On that score, there is a 4 part tutorial where I supply a model & use the various tools to paint it. Given that I talk quite a bit about workflow, it can be useful even if you don’t have the Art Studio. So here’s the link for that - https://www.youtube.com/watch?v=0G64ibbgNO8
Hi, I bought the brushes from you. Really nice textures in there and really cool work! Your videos are great too.
But I have one problem: the metal brushes don’t seem to work, or maybe I don’t understand how to use them. I don’t know if any settings are wrong, but nothing happens when I try to paint with them.
Hi Nilz, sorry to hear about this. I checked the particuar brush you look like you are using - 42 Copper Oxide?’ and here’s my screenshot with that brush plus a few others:
Although I appreciate that you say all the metals have the same problem. So check a few things. With Stroke Painting enabled and a new scene the default sphere, & set to PBR lit mode:
Show paint switched off in the Shading menu. PBR can be enabled while painted colour, roughness and metalness are hidden.
Check if the tool intensity is at zero or very low. It’s worth checking separately from the Nomad Sculpt 2.9+ paint slider you’ve already confirmed.
Check for a mask on the sphere. Clear it explicitly rather than relying on whether it looks masked.
If you’re using a stylus, try a finger or mouse stroke. That might help isolate a pressure or input issue.
The most useful test now is Paint All with one of the affected tools selected. If that applies the metal correctly, the material and its display are working; the problem is in how the stroke is being applied. If Paint All also appears to do nothing, I’d concentrate on Show paint, masking and any active layers.
Try painting with the factory paintbrush and does that work? If it does, turn on the roughness slider and paint a few strokes while you vary the roughness. Do the same with the metalness. Does that work? Knowing that might help to narrow things down.
If that doesn’t work, is there any chance of a short screen recording showing them selecting the tool, painting a stroke, then pressing Paint All? It’ll work better than us playing screenshot tennis.
No worries! I think I misunderstood how it works. I expected to select a metal and have a matching alpha that adds the texture as I paint. Instead, I choose the metal colour and then use separate brushes to create the texture. My bad!
I was expecting something like smart materials, but now I understand it’s more of a material sandbox. I’ll spend a bit more time playing around with the brushes.
Sorry for the confusion, and thanks for getting back to me!
