Is there a way to set symmetry not globally, but separately for every mesh ? For some meshes I disable it, but then I sometimes forget to turn it back on when switching to a symmetrical mesh.
Thanks.
Ron
Thanks.
Ron
Go into the Symmetry options. Scroll all the way down and there’s an option “Gizmo Edit”. Try that.
Go to the symmetry icon on the top right menu & you can select local or global for you object symmetry & also have the choice to show the plane or a line & also to change the axis between X Y & Z
Thanks, but those are not working.
What I mean is, suppose I have 2 meshes. For one I use symmetry, for the other not.
What I’d like is to automatically have symmetry switch on and off when I select each mesh.
It seems that with “symmetry edit” I can transform the symmetry plane. And with the “local or global” symmetry switch I can lock the symmetry plane to the mesh when I transform it with the gizmo, or keep it at world coordinates.
The symmetry settings are per object (position/rotation) but not the enable/disable state.
Ah, thanks. That would be a handy feature.
I’ll put in a feature request for that then.
