when using the trim and split tool it would be ideal to be able to turn on snapping. In general being able to turn on/off snapping when doing practically anything in Nomad would be great.
There is snapping for trim / split …
What are you missing?
Wow, that was a fast response. thank you. Maybe I’m missing something. I do not see the snapping option when I use the trim tool and the rectangle selection box it’s free form. When using the gizmo its available but not when I click on the trim tool, see attached images
It only seems to work for the polygon.
Align the view + grid + polygon tool
Then the snapping icon appears next to the view cube.
If you need a square or a circle, then switch auto validate OFF → draw the contour and then switch to the polygon tool → the contour is retained and you can activate snap and move the contour.
