Hi, anyone knows if it’s possible to save files in different folders, just to keep data in order and also I’d like to have some specific folder to use as asset browser so I can reuse props in multiple projects.
Thank you!
Thank you!
Yes you can, just use the export feature, then choose a folder or create a new folder and name it what ever is appropriate, then when you want to import your sculpt ,use the add to seen, select from whatever folder you wish to import from and that’s it, hope this helps
Yes, you can save the objects in different folders.
Press Save As.
When entering the name: FolderName/ObjectName
thanks so much!
Woah mate, thanks a ton. Didn’t know that one.
Probably then creating the folders on the files app would also give ready to go folders to choose from.
