Removal of Alpha Brushes
Could someone please let me know what the default alphas are? Over time I’ve imported a bunch of alphas and want to clean them out back to initial installation. As far as I know Alphas are not touched when using the Reset to Default button in the Project tab. I don’t want to delete default alphas that may be used by default brush settings.
You can simply rename the “alphas” folder to ignore all your alphas.
(However if you add it back all the thumbnails will be generated which can takes a bit of time if you got load of them).
That being said, there is only 2 base alphas.
And you can’t deleted them.
Awesome! I hadn’t noticed how many were in there by default. Thanks for your help Stephane (as always!)
