Hi,
I imported a 3d file into my scene and suddenly all my work turned gray, I think because off the remodeler or quad, it i click in this tool it goes back to normal, but if i click on another tool to edit it turns gray again and i cant see anything.
What can i do ?
Do i need do buy this tool ?
Is there any way to disable it ?
Are you sure the models that you imported aren’t simply not colored grey?
Maybe go in the paint menu and use “paint all”, or go in the “materials” menu to see if you have textures.
The Quad Remesher overrides the painting to force a white material, so it can’t be the culprit.
Thank you very much. The problem was in the light. It was in matcap instead of pbr.
Thank you very much for your help.
