- When using the profile in the Tube tool, the minimum unit of Spacing will increase as the profile becomes larger, which is very unfavorable for fine control of cross-section modeling.
- In Profile, when there are many control points, multiple points cannot be moved at the same time.
- When there are too many Profile points on Tube, the entire Tube is easy to bend, and how to make it straight through constraints is also a problem.
If the above three problems can be solved, Tube will be a more powerful and complete tool!
For point 3 in your list, try lowering the accuracy % when drawing a freehand curve. This reduces the number of points used to interpolate the curve, which makes the process easier.
