Radium clay scene zip crashing when trying to download
Upon installing the 2 files needed to run the program, the only file that is giving me trouble is the clay scene zip. When I try to download it nomad crashes immediately.
The file is +1GB, these are multiple nom projects.
You shouldn’t load all of them at once or it will use lot of memory, and loading multiple nom usually not what you want to do.
You need to unzip the file, then drag the folder (or the nom files) directly in the “projects” folder. Then simply restart nomad and the projects will be available in the “open” menu.
Alternatively you can unzip the folder. And open the nom files one by one (and saving them if you want it to).
