Problema Visualización renders estatico en nomad sculpt 2.8 tras la ultima actualización del IpadOs al 26.4.2
THE PLATFORM: iPad,
NOMAD APP VERSION: 2.8
Hola, tengo un ipad pro 11 con el chip M5, y hasta ahora nomad me funcionaba marvillosamente, pero tras la ultima actualización del IpadOs al 26.4.2, he comprobado que cuando realizo un render estatico, da igual a que resolución, la pantalla de visualización del render me aparece en negro con el nombre del archivo, aunque me permite exportar el render sin problemas, pero no verlo,… Se agradecería alguna idea para solucinarlo,… he probado todo lo que se me ha ocurrido. Gracias…
I can’t seem to replicate on my device (same version for Nomad and iPadOS).
Does it happen on any project as well or just a specific one?
Maybe restart the iPad (just in case or an iPadOS issue).
Following your kind reply, I carried out checks and it happens with three files, including the recent one I am modeling for the exam. I’ve tried every solution I could think of with the files and the iPad, including restarting, and it’s still not fixed. It’s not the file size, since the latest one is 547GB, and I’ve worked with Nomad files as small as 1.9GB without any problems, although I eventually reduced them to 247MB for safety, with no noticeable loss of quality. After the battery of tests I mentioned at the beginning, I’ve concluded that the problem lies in the folder where the file is located and opened from—the Nomad project folder. I’ve copied the file to a folder on the intranet where I have a backup of the modeling files and another to the iPad’s downloads folder. After opening each file directly in Nomad, I generated high-resolution renders with 1000 passes, and they displayed correctly. So, the conclusion, strange as it may seem, is that the file in the Nomad project folder has some kind of problem, but only in that folder. The projects folder… Thanks for your help, now let’s see if I can figure out the cause of the problem… thanks again…
