When I select one of the file formats for export and tap export, nomadsculpt freezes.
Using version 1.87.
Check it please thanks
Maybe give more information. Android, iOS?
How big were the scene?
Thanks for the reply.
I am using an iPad pro.
And in every scene it happened.
For example, even with one ball out.
While waiting for your reply I tried to force restart the iPad.
After restarting, the same problem has not happened.
I am sorry for the trouble you are going through.
It seems to be OK now, so I will wait and see how it goes for a while.
Thank you for your time.
If it happens again, maybe try other software to see if it’s not an issue with the share popup.
On my iPad I got this very annoying popup where the share popup simple stops working.
And it won’t work in other softwares as well, it’s super annoying and rebooting is the only fix I found.
I suspect an iOS issue.
