Problem with "mask" option in Edit Pivot menu?
I’m on Ipad pro using nomad 2.8.
I’m trying to edit the pivot to be precisely on an unmasked vertex. I’ve done this loads of times in the past and it always seem to work without any issues, but I can’t seem to get it to work anymore. In the edit pivot side bar menu (the one with”auto”, “center” “align” options etc) the “mask” option appears to be greyed out and tapping on it doesn’t do anything. Is this an issue/bug or has the behaviour changed and I’m doing something wrong. Any help appreciated thanks
Here it works - also Ipad 2.8
That’s strange. Your version is behaving like mine used to. But my version has the “mask” option greyed-out and unselectable, see pic. Maybe a bug?
Maybe, I don’t know, but I use a Bata Version. Maybe there was a bug…
If you disable pivot, target should be set on vertex (or auto).
But I’ll change this behavior.
thanks for explaining that!
