Objects gizmo reverts after pivot adjust and save issue
when I select an object and go to adjust the pivot and then close pivot, the pivot point default back to its original spot after I make any adjustments on a non-validated object.
Also, went to save a file I was working on the other evening and it tried to save it under another file name.
iPad Pro 11 in.
second generation iOS version 18.6.2
If a filename already exists it will increase the iteration number rather than override another project.
