Objects vanish from older file after attempting to zoom in. If I try to open another file all objects remain gone I have to force quite the app to make it work like normal. I haven’t found another file that replicates this. I can message you the file if needed.
M4 iPad Pro 1tb - nomad 2.2
Update
It’s a lot of my older files. This bug is making it so I can’t work on older files at all. I tried to make a new file and import the old file but even that yields the same reaction of everything vanishing. Please help ![]()
Just send the file.
And when the bug occurs restart Nomad.
The faulty object is boot2 → box1 make sure to delete it.
Not sure what caused it but it’s possible the cause of the bug will be fixed (primitive with infinite or 0 dimension, etc)
Got it. I have several other files that are affected as well. I’ll standby to see if the other files correct after the patch. Thanks again for everything ![]()
